Latest post 04-09-2009 2:26 PM by birgerbum. 9 replies.
Page 1 of 1 (10 items)
  • 04-07-2009 3:55 PM
    • juupke
    • Not Ranked
    • Joined on 04-07-2009
    • Posts 4
    Beovision LX5500 + Philips DVD recorder werkt niet.
    Hallo,
    Ik heb een Beovision LX 5500 TV en een philips DVD recorder aangesloten via de scart. Normaal films kijken met de DVD recorder werkt goed met de scartingang 2 als videotape aangesloten. Maar zodra ik de DVD stop en na de timer of menu van de DVD ga wordt het beeld zwart. Heeft iemend een idee hoe dit komt en hoe dit op te lossen is?
    Alvast bedankt
    Peter
  • 04-07-2009 4:58 PM In reply to
    Re: Beovision LX5500 + Philips DVD recorder werkt niet.
    HI
    Please refrase your question in english and I may be able to help you
    Regards
    jan
  • 04-07-2009 5:20 PM In reply to
    • juupke
    • Not Ranked
    • Posts 4
    I have a Beovision LX 5500 and a Philips DVD recorder. To play a DVD works fine but when I use the tuner function or menu of the DVD recorder the screen turns black. The DVD recorder is connected via scart 2 input.
    Thanks in forward
    Peter
  • 04-07-2009 5:29 PM In reply to
    Hi
    Please tell me the Model number of your phillips dvd recorder and what kind
    of television standard you are using its in the nederlands i presume you are
    using pal g correct me if i am wrong.
    regards
    jan
  • 04-07-2009 5:35 PM In reply to
    • juupke
    • Not Ranked
    • Posts 4
    Philips DVDR 3380 and we are using indeed Pal G.
    Peter
  • 04-07-2009 5:38 PM In reply to
    Hi
    When you enter menu and tuner setup is the picture there but no colour
    or is it all black
    regards
    jan
  • 04-08-2009 4:57 AM In reply to
    Hi Peter
    as you did not answer my last post I can suggest several possibilities
    try to use your tv/monitor button on your  dvd remote if it do not work
    its possible that your dvd  are configured to ntsc or auto and not able to
    send the right signal when your dvd is in stop mode,another possibility
    is that when you are in stop mode,the dvd do not send 5V  to your tv
    but when in play mode it does,try to use a rca video/sound cable its a 3
    core with a red white and yellow plug in both ends and connect them to
    your video/sound rca connections on the back of your dvd,you also have
    to get a scart adapter  with rca connections you can buy them by a dealer
    to connect to your scart av2 on your tv if you are able to see your menu
    from your dvd enter the menu and change the output format to either rgb or composite and set it to pal
    regards
    jan
  • 04-08-2009 8:59 AM In reply to
    juupke:
    Hallo,
    Alvast bedankt
    Peter
    Gebruik je wel een volledig bekabelde Scartkabel?
  • 04-08-2009 4:05 PM In reply to
    • juupke
    • Not Ranked
    • Posts 4
    Hi Jan,
    I have put a RCA cable between the TV and DVD recorder and it works. I think that indeed the problem is the 5V signal. The signal of the DVD recorder was PAL so that was good.
    @ damatt. De stekkers van de scart kabel hebben alle pinnetjes dus ik ga ervan uit dat ik een volledige kabel heb.
    Ook bedankt
    Peter
  • 04-09-2009 2:26 PM In reply to
    HI
    Happy to hear that it works
    regards
    jan
