Latest post 04-07-2009 3:20 AM by Die_Bogener. 1 replies.
Page 1 of 1 (2 items)
  • 04-06-2009 5:30 PM
    • Kiwi
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 45
    Dead Avant tube, long live the speakers ?
    I was wondering if I still could use the speakers (and maybe some electronic parts) from an old Avant with a defective tube and use the speakers as a stand-alone solution (like i.e. beolab 4000).
    Anyone any experience with this?
    Kurt.
  • 04-07-2009 3:20 AM In reply to
    Re: Dead Avant tube, long live the speakers ?
    yes, it works. The Avant has 2 seperate amplifiers, using a powerlink interface... or at least compatible with powerlink. You need only a 60 Watt power supply.
    The plastic box with the loudspeakers sounds nice, but looks awfull. The speakers are compatible with Beolab 2500.
    If you build a box in a wall, behind the sofa or under the desk, they sound great. But they should be installed invisible.
