Latest post 04-07-2009 3:23 AM by beolife. 1 replies.
Page 1 of 1 (2 items)
  • 04-06-2009 4:45 PM
    STC not controlling Mac Mini but does control Sky+!
    Hi Guys,
    Hope you can help, updated the STC in my Beosystem 2 to enable control of the Mac Mini, the Mac is set to (stb)V.Aux & set to apple remote but it does not work, it's not even flashing at all but the Sky+ can be controlled as normal.
    Any Ideas.
    Regards Simon
    Filed under: ,
  • 04-07-2009 3:23 AM In reply to
    Re: STC not controlling Mac Mini but does control Sky+!
    Managed to get it work but only if I removed the DTV STB from the connections list which is connected to the camcorder input, then it worked but if I put the DTV back in the SKY+ works but not the Apple.
    Here is a list of the connections used
    VMEM-DVD (sony)
    AV-DVD2 Wii
    DECODER-STB-VAUX (Mac Mini) set to apple remote
    CAMCORDER-STB-DTV (SKY+) set to sky+
    Really not sure why this is happening but very frustrating hopefully someone can shed some light on this issue.
    Regards Simon
