Latest post 05-31-2007 1:21 AM by nickj. 6 replies.
Page 1 of 1 (7 items)
  • 05-30-2007 1:48 AM
    • nickj
    • Not Ranked
    • Joined on 05-30-2007
    • Posts 2
    touch panels
    My Beosystem 3500 (Beogram, B'cord, B'master) is mounted on a wall & the touch panels have begun to fall off. Does anyone know of a specific padded tape that I can use to fix them back on with? Craig (Apr 24 '07) mentioned using thin carpet tape - care to be more specific, please?
    NickJ
  • 05-30-2007 1:54 AM In reply to
    Re: touch panels
    I would use impact adhesive. You are unlikely to want to take these off again - why not make it permanent?
  • 05-30-2007 2:54 AM In reply to
    Re: touch panels
    I fixed it at our Beosystem/Beomaster 4500. The touch glass is mounted in frames with foam.
    Repair: See the instruction on the Beomaster bottom for dismantling the glass panel.
    Get sticker glue remover/cleaner, remove the glass from the frames and glue the frames to the glass with very small layer/amounts of car windshield glue/kit (black kit), not the short hardening glue/kit. Do it at ease, take your time. Stunning system at the wall !!
    Regards, Robert
  • 05-30-2007 8:35 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: touch panels
    Hi, the tape I referred to was this type.
    CARPET TAPE
    CraigBig Smile
  • 05-30-2007 3:55 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    Re: touch panels
    I've reattached mine and it won't come off again BUT i'm still too scared to mount it on the wall. I'm petrified it'll fall off. Stops me from sleeping everytime I hear something I thinks its falling off!  Don't how you guys do it considering there aren't any more replacement panels!
    Durban South Africa
  • 05-30-2007 7:41 PM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-17-2007
    • New Zealand
    • Posts 119
    Re: touch panels
    I reattached mine with black neutral cure silicone. I'm 100% certain they'll never come off ever again!
  • 05-31-2007 1:21 AM In reply to
    • nickj
    • Not Ranked
    • Posts 2
    Re: touch panels
    Thank you all for your suggestions. I think that the silicone/ windscreen goo is likely the best way. Neither of them cure to a hard finish & they remain flexible.
