HI hudspau
your problem are most likely bad soldering around your line transformer its located in the right backside of your chasis looking from
behind,resolder your line transformer and components around it if you dont know what a line transformer looks like you cant miss it
its the biggest transformer on the chassis with a red core that goes to the picture tube.be very carefull you are dealing with high voltage
and even after you unplugged the tv you still have high voltage.if you are not familiar with working on tv sets leave it to qualified
technichians
regards
jan
