Latest post 05-30-2007 4:18 PM by Iconic-AV. 5 replies.
Page 1 of 1 (6 items)
  • 05-29-2007 9:22 PM
    • nrhalne
    • Not Ranked
    • Joined on 05-13-2007
    • Denmark
    • Posts 18
    Used beovision 3 vs MX8000.
    Hi
    My tv LX28002N is too old now and I am looking for a replacement. My choise is now between Beovision 3 or a MX8000 (950 - 1250€). The beovisen 3 is about 600€ more than the MX8000 and I can`t affort the flat screens yet. I like to lisend to music and watch movies and the plan is to add a couple of good speakers or maybe go for surround. Is there sourround module in both models and is it working. I have not seen any of them live. Can anyone give me some advise what to go for and why.
    Thanks. nrhalne.
    Filed under: ,
  • 05-30-2007 1:59 AM In reply to
    Re: Used beovision 3 vs MX8000.
    If it is a 32" BV3, go for that. Better sound and basically an Avant. Make sure it has the surround module. If you are watching movies, you want a widescreen. The picture is as good as the flat screens - better than most of them! It also looks like a flat screen from the front!
    If a 28" BV3, get the MX! Same chassis but much bigger screen on the MX.  The 28" BV3 was a loss leader used to get people into the shop - unless it has been optioned up, it can be quite basic and the sound is just not as good.
  • 05-30-2007 2:19 AM In reply to
    Agree with Peter !00%. BV3-32 is very good value at the moment.
    Regards Graham
  • 05-30-2007 9:03 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Go with the BV3, you will not be disappointed.
    CraigBig Smile(Happy BV3-32 owner)
  • 05-30-2007 3:03 PM In reply to
    • nrhalne
    • Not Ranked
    • Denmark
    • Posts 18
    Hi All 3
    Thanks for the quick help. I will go for the 32" BV3.
    Does anyone need 3 ea LX2802N.
    Nrhalne.
  • 05-30-2007 4:18 PM In reply to
    i think youve made the right choice,  you could always get the mx8000 for the guest roomSmile
    jay (another happy bv3 32 owner)
    jason
