Hi all
I've connected a Mac Mini computer to my (non-B&O) television, and now I'd like to connect a pair of BeoLab 6000 speakers. I believe there's an adaptor available to convert a 3.5mm plug (from the mini) to a powerlink cable (6000), and then I would 'daisy chain' the powerlink cable to the second speaker.
Is this correct? Can I control volume using the mini?
I've read in other posts that another B&O system is needed to control volume - I do have an Ouverture in another room, but I don't really want it next to the television.
Hopefully this makes sense...
Thanks in anticipation
Stuart
