Latest post 04-06-2009 3:24 AM by Ehlerz. 8 replies.
Page 1 of 1 (9 items)
  • 04-05-2009 7:36 AM
    Turning all linkrooms on from one room?
    Hi
    Just want to know if it is possible to turn on all linkrooms from one room, like it is possible to turn them all off by pressing and holding the off button down?
    Thanks in advance
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 04-05-2009 7:39 AM In reply to
    Re: Turning all linkrooms on from one room?
    Hi I think that this cannot be done, as you say you can turn them all off.
    Cheers Nick
  • 04-05-2009 7:59 AM In reply to
    The only way is to activate the Timer in all rooms, and then program an audio source at the time you want the music in all rooms.
    p.
  • 04-05-2009 8:03 AM In reply to
    Ok, just weird as it is possible to turn everything off. Say you are throwing a huge party with people in all rooms and you want the music played allover without having to activate every linkroom manually.
  • 04-05-2009 8:57 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Ehlerz:
    How many rooms are we talking about here? The answer to your question, is still no. lol
  • 04-05-2009 9:37 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Ehlerz:
    Actually this ix a feature, not a bug...meant to preserve harmony in the household.  If it were possible to activate every room in the house, then it's possible to do so by accident.  How many times will your loving spouse allow you to awaken her (or a sleeping child) before the trouble starts?  Devil
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 04-05-2009 10:18 AM In reply to
    Everyones comments about this situation are correct, you cannot switch on all linked rooms from one room by user action.
    However you may be asking yourself, technically why this is the case, the answer is that B&O's Masterlink protocol uses what they call a "Lock Manager Protocol" which uses a "KEY" which any product must hold before an action can take place for that product. There is only one key, and if another product needs it, then the key must be requested on the bus and the product currently with the key passes it to the new product asking for it.
    Everyone knows that the Masterlink must have either a Video Master or Audio Master for the system to work, but why ?, the answer is to create the "key" on power up. So, you ask, what if I have an Audio Master and Video Master on the same Masterlink, do I get two keys ? the answer is NO, there is only ever one key. On power up the Video Master (if it exists) will create a key and after a delay of around 2 seconds from power up, an Audio Master will check to see if a key exists and if not, it create one. ONLY a Video Master or Audio Master can created a Masterlink Lock Manager key.
    However when you press the Standby for two seconds to turn everything off it does not use the Lock Manager, and it effectively sends a reset command which all products pickup from the bus and use to switch themselves
    Regards Keith....
  • 04-05-2009 10:40 AM In reply to
    For those who want to expand the possibilities of the ML, B&O now has the ML Gateway:
    http://www.bang-olufsen.com/masterlink_gateway
    You would need one of these, plus a computer and a Beo5.
    You could add a Beo5 command, which would be passed onto the ethernet cable by the ML gateway, received by the computer, which would in turn send commands for every room to switch on.
    Probably a little bit overkill for a feature that is not really needed...
  • 04-06-2009 3:24 AM In reply to
    Thank you for all your replies. I guess it is not possible, at least not out of the box.
