Hi
Having just discovered this forum and although I am technically ignorant, I really want to get the best out of my system - it is such a work of art, it deserves to be looked after! So here goes
I have a crackling S80 with my Beocenter 7002. Switched over speaker leads and channels and it is definitely the speaker. It occurs more in the bass range and when you push the volume past '6'. Is it to do with the crossover unit? If so how do you fix it? I do not know if it is connected but the lights on the front of the speakers have never worked. Is it just a case of blown bulbs or is it related in any way?
Finally I need to move the system to another house and would like to know if there is any smart way of securing the turntable & arm. I remember bringing it home and it was bouncing away so much, I fear it will get damaged.
Ciao, ciao
Liz
