Latest post 04-03-2009 11:54 PM by TripEnglish. 3 replies.
Page 1 of 1 (4 items)
  • 04-03-2009 11:03 PM
    • Yendys
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Sydney Australia
    • Posts 100
    BM5 with an Avant?
    I see in the thread ‘At Last’ you can purchase a MB5 on its own.  I’ve yet to ask my local dearer in Australia…..
    But does any one know if it will work with an Avant DVD in the same way as it does for the current range of beovisions?  And would the Avant need any upgrades.
    (I also have Beoports and BS3000 in my setup)
    BV10, AvantDVD, BS3000, BL8000, BL6000, BL4000, BL3500, BeoPorts, BC9300, BC7002, CX100s, C75s, Beo4s, BC6000s, LC2s, A9, A8s,
  • 04-03-2009 11:18 PM In reply to
    Re: BM5 with an Avant?
    Currently no, but that will change by late summer/early fall. Basically the new BeoVisions control the BeoMaster 5 via MasterLink and the older televisions can't. The BeoMaster 5 will have to be controlled with its own IR eye but that is not currently supported in the software.
    This has been discussed internally as part of the roll-out. I'm really not sure why it's so far in the future, but it is definitely planned.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 04-03-2009 11:44 PM In reply to
    • Yendys
    • Sydney Australia
    • Posts 100
    Thanks TripEnglish.
    To confirm; there is an IR port on the BM5 but it isn’t currently supported and that is how you will be able to control it with an older Beovision (e.g. Avant) when this port is supported/enabled.
  • 04-03-2009 11:54 PM In reply to
    You are correct sir!
