Latest post 04-04-2009 2:44 AM by Nickyg63. 4 replies.
Page 1 of 1 (5 items)
  • 04-03-2009 3:48 PM
    Connecting Overture/4000 to Beolab 2000
    Hello,
    I know they are both older pieces and not very current but I have a simple questions.  I would like to connect the two pieces Overture/4000 to Beolab 2000 together and know I need a masterlink to do so, where is the best place to purchase one from???  Also do I need a certain type of masterlink or are all the cables identical???
    Would this be a fairly easy to operate system???
    Also I am located in Canada if that matters....
    THANX
    andy
  • 04-03-2009 4:02 PM In reply to
    Re: Connecting Overture/4000 to Beolab 2000
    You just need a masterlink cable long enough to reach from the 4000 to the 2000. Your B&O dealer can supply cable and accessories.
    Regards Graham
  • 04-03-2009 4:16 PM In reply to
      I have done this myself its very easy to do! You may need to cut the cable to pass through walls you can get a masterlink junction box from your dealer.  Buy a large box as the small is harder to fit the two cables in, Also buy a genuine cable I believe them to be of a better quality!
    Hope that helps
    Cheers Nick
  • 04-03-2009 10:27 PM In reply to
    DAMN I was hoping to be able to order the cables over the internet it is a long way to my dealer!!!!
  • 04-04-2009 2:44 AM In reply to
    There is nothing stopping you getting them off ebay or wherever, If your a competent diy'er you will be fine!
