Dear all, I am considering the following (simple) set-up: MacBook Aluminium -> Airport Express -> B&O audio master. I will use an iPod Touch with Apple Remote in order to remotely access my music library, which will be in a lossless format. Now I have two questions for the knowledgeables among you:
1. As my B&O audio master has no digital input, I will have to use the analogue Aux input. But I am not sure that the MacBook's/Airport Express' analogue output quality is at par with the B&O audio masters'. So, in this configuration, will the MacBook's/Airport Express' built-in DAC be decent enough or will it significantly deteriorate the music quality? As the case may be, is there any way to circumvene this issue?
2. When I will use the iPod Touch to access my music, I won't want to use a second remote (i.e. my B&O remote) to control the volume. So, is there any way to use the iPod Touch in order to remote control the B&O audio master volume (alternatively, if this is not possible, is there a way to control the MackBook's output volume)?
Thanks a lot for your valuable input. Cheers, Jean-Sebastien
