Latest post 06-15-2007 4:56 AM by jchasey. 5 replies.
Page 1 of 1 (6 items)
  • 05-29-2007 4:11 PM
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Beosystem 3 and DVD
    If I'm using a Panasonic DVD player, do I need a DVD Controller or would the Beosystem 3 be able to control it? Reason I ask is that I have only the choice of the 2 B&O DVD players or Unknown DVD in the PUC.
    Filed under:
  • 05-29-2007 4:24 PM In reply to
    • Max
    • Not Ranked
    • Devon
    • Posts 64
    Re: Beosystem 3 and DVD
    I believe so, you can only control set top boxes with the Beosystem 3.
    My B&O is in my Bio.
  • 05-29-2007 5:39 PM In reply to
    • zed06
    • Not Ranked
    • Joined on 05-29-2007
    • Posts 6
    Wich DVD player Pana is it exactly ?
    Your retailer can update the STB C list with his computer !
    I'm a french retailer, I know the problem !
    It takes really 5 minutes to do that !
    If you bring your BS 3 he could be do that for free.
  • 05-29-2007 6:14 PM In reply to
    • frog
    • Posts 191
    Thanks - it is the DVD-S97 (first one with HDMI). It worked OK with the DVD Controller. I just don't think it is necessary to have to use it now with the PUC.
    How do they update it exactly? Do they choose from a list on a menu or do they just put all the boxes they have in the ROM?
  • 06-13-2007 5:39 PM In reply to
    • zed06
    • Not Ranked
    • Posts 6
    We do as we want : on the computer, we have a list of products, we can choose one, or all (one by one). the creation of the data list is about 5 minutes for 5 products....
    And after, we update the Beovision or Beosystem3
    That's all !
  • 06-15-2007 4:56 AM In reply to
    • jchasey
    • Not Ranked
    • Joined on 04-17-2007
    • Hampshire, UK
    • Posts 11
    Can you post a list of which DVD make/models are available to support?
