majand:
Hello,
Do these work together? And can be turned with BL1000?
BR,
Pekka
I've never known a MX5500 not work with a motorised stand.
Unplug the TV from the mains, mount the TV on the stand and plug the flying lead into the 4 pin socket marked STAND.
Now switch on and select a channel. Press PICTURE on the BL1000 and you should have the STAND command as well as brightness, contrast, colour etc. Move the stand with the << and >> keys or one of the other arrows, I can't quite remember.
STAND should also be displayed in the SETUP menu so that you can pre set your favoured watching position.
