Latest post 11-15-2011 4:27 AM by beonils. 6 replies.
Page 1 of 1 (7 items)
  • 03-30-2009 4:39 PM
    • Mito
    • Not Ranked
    • Joined on 03-30-2009
    • Posts 3
    Beocom 6000 Mk 1 Display not working
    Hi There,
    All a bit new to me this forum stuff !
    I have what I believe to be two beocom 6000 mk 1 and a becom 2 working via a PSTN base and all work fine. The LCD display on one of the Beocom 6000 doesn't work (the green type back light does) which is a bit of an issue when your trying to locate a number in the phone directory. Does anyone have any idea's what I need to fix this issue as my local dealer advises me to chuck away and start again!
  • 03-30-2009 4:55 PM In reply to
    Re: Beocom 6000 Mk 1 Display not working
    When you open the Beocom 6000 you will find a white contact rubber for your display.
    Most of the time that is the problem and when you replace it the change is 90% that it works again
  • 03-30-2009 5:02 PM In reply to
    • Mito
    • Not Ranked
    • Posts 3
    Thanks for the prompt reply. Can I buy this contact rubber from my B&O dealer if so do you have part number?
  • 03-30-2009 5:17 PM In reply to
    Try taking the battery out of its socket. This has worked for me a couple of times..
    But sometime you need to have the contact rubbers replaced..
    BMGHB
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 03-30-2009 5:31 PM In reply to
    • Mito
    • Not Ranked
    • Posts 3
    Removed battery and reconnected but no different!!
  • 03-31-2009 7:37 AM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Part number is 7500301, price not worth saying
  • 11-15-2011 4:27 AM In reply to
    Hi, I joined you because I got the same pb since the tel fell on the floor.
    I can't get de tel opened, do you need a special tool? There are certainly some hidden clips, because after unscrewing the 2 under the battery ti doesn't move a damn. Can somebody give me hint?
    great to hear from you,
    beonils
