1st March February 2012
Latest post 04-03-2009 3:13 PM by wirralsimon. 14 replies.
Xseries
- Joined on 04-16-2007
- Hampshire
- Posts 433
Re: Can I activate the Aux1 socket on an LX2800 with a Beolink 1000?
I think "Shift" + "TV" should achieve what you are after.
Brian
dko7113
- Joined on 09-04-2008
- Copenhagen, Denmark
- Posts 104
Brian is right: "AUX" on Video Terminal = "SHIFT" + "TV" on BeoLink 1000
Erik
My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
lloydern
- Joined on 06-27-2007
- Oslo, Norway
- Posts 110
Hi Jimmy!
Acually, you need also to choose between aux 1, 2 or 3 to activate the right socket.
You press "shift" + "TV" + 1.
Great sound on your television! It's amazing from an over 20 year old product. I have one too, that I've got for free some weeks ago. Marvellous sound...
Lloydern
Anything but Beo isn't an option...3-32, Overture, DVD1, Beomedia, V8000, lab 4000, 2 x lab 2000, 2 x lab 6000 & lab 11.
jimmythesaint
- Joined on 03-30-2009
- Posts 4
Many thanks guys. I can't make it work though. According to the manual, to activate the aux 1 without a TV picture (which is what I want to do ideally) I just switch on the TV with the Aux button (i.e. SHIFT + TV). When I try that all that happens is the TV comes on as normal. Any advice? Ben
p.s. Thanks Lloydern. It looks like the SHIFT button on my remote isn't producing an IR signal, so that would explain why nothing is working. So I'm a bit scuppered for the time being. I don't know how to fix the remote!
lloydern
- Oslo, Norway
- Posts 110
Hi again!
When you press "shift" + "TV" you are supposed to see a little red text on the screen saying "AUX", and then you press the aux number.
If this doesn't happen with your remote, maybe there's something wrong like you suggested. That's too bad!
But don't you have a Beo 4? You can just add "shift" to the "list"-function and take it from there I recon...
Lloydern
dko7113
- Posts 104
If you have a Beo4, you can just add "V.AUX" to the "LIST"-function.
"V.AUX" on Beo4 works as "AUX" on Video Terminal.
Erik
lloydern
- Oslo, Norway
- Posts 110
...of course..."V.AUX" on Beo4 is the best solution....
lloydern
jimmythesaint
- Posts 4
Hi again guys. No Beo4, unfortunately. Just the Beolink 1000. So the SHIFT +TV would be the answer here... except the shift button seems to be kaput (I presume it should emit an IR signal when pressed, like all the other buttons. Mine doesn't, for some reason). So that seems to be the problem. Looks like I need a new remote... Thanks again for your help so far though - much appreciated.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
No, I don't think [SHIFT] shall emit a signal. It will use the second used button to emit a special wanted signal.
For example. [TV] emits a command to activate TV, but [SHIFT] [TV] shall not send the command TV but [AUX].
Other example [SHIFT] [LINK] on my Beolink 1000 sends the command [LIGHT] that a newer remote can emit with one press. But it's still only one signal emitted.
jimmythesaint
- Posts 4
Hi. I Kind of suspected as much, so I persevered and lo and behold I've sorted it. It's two presses on SHIFT + TV. Works perfectly. Fantastic. Thank you all for your help. Ben
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi Ben,
Glad you've got it sorted! I've been trying to track down an LX2800 to test this out and find the answer, but you've beaten me to it! I have added a note to the product page for this cable, giving the remote commands for Beo4, Beolink 1000 and Beolink Video, including the combination for Beolink 1000 when used with an older TV such as the LX2800.
Hopefully, this will help any future users wanting to connect an iPod to their Beovision TV.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
wirralsimon
- Birkenhead, UK
- Posts 1,253
I am glad I read this thread because I was wondering earlier in the week if there was any way to play audio through the LX2800 in my bedroom, and this thread appeared.
I have just ordered one of Steve's cables!
Simon
- Posts 356
Hi Simon,
Your cable went out this morning First Class, so it should be with you very soon. I will be interested to hear your comments on this when you've got it connected up!
Many thanks
Steve.
wirralsimon
- Birkenhead, UK
- Posts 1,253
Thanks Steve
The cable arrived yesterday and everyhting is up and running, for the time being into my LS5500 using external speakers.
It sounds a lot better plugged into the back of my iPod dock than it does plugged directlty into the iPod, sio that is how I am using it. It means I have a listenable music system in a room that otherwise wouldn't have one.
Simon
Page 1 of 1 (15 items)
