Latest post 04-02-2009 11:04 AM by Dillen. 9 replies.
Page 1 of 1 (10 items)
  • 03-30-2009 12:50 AM
    • GeoffR
    • Not Ranked
    • Joined on 03-30-2009
    • Posts 3
    Beolit 707
    I have owned a Beolit 707 since new (1975).  It has a serial number of 000001.  Still in good working order though showing signs of use.  It is likely that it might it might be of interest to collectors, etc.??
    Geoff
    Filed under:
  • 03-30-2009 3:42 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beolit 707
    Hi Geoff and welcome to BeoworldSmile
    If you are to offer it for sale in this forum then minimum silver membership level is required to post it in the sales section.
    These are definately sought after radios although I'm not sure of the significance of the serial number as I'm no expert but if it is the first one made then it will definately add to the collectability and HERE is the place to offer it to a serious collector. If it is simply a standard issue item then ebay is the best place to gain the best price. Ensure you have a good description & photo's and that it is listed in the correct sections of ebay.
    I would be surprised if it sells for less than £100 if all the parts are intact & original.
    Chris.
  • 03-30-2009 5:28 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beolit 707
    Geoff,
    Very interesting though I am a bit sceptic regarding the serial number.
    They are normally somewhere around the 1610000-1620000 range for the Beolit 707's and
    B&O only used the serial number 1 once, and that was back in 1925 or so.
    A photo of the number would be great to see if possible.
  • 03-31-2009 5:03 AM In reply to
    • GeoffR
    • Not Ranked
    • Posts 3
    Re: Beolit 707
    Dear Martin
    I am also a bit sceptical, that's why I am asking the question.  But here are some photos, including the serial number on the base.
    Radio
    What do you think?
    <!--[if !vml]--><!--[endif]-->
    Geoff
    Filed under:
  • 03-31-2009 1:00 PM In reply to
    • Dillen
    • Posts 5,008
    Re: Beolit 707
    Strange indeed.
    The only explanation I can think of is that some major part - maybe the whole chassis - was replaced at some point.
  • 03-31-2009 7:49 PM In reply to
    • GeoffR
    • Not Ranked
    • Posts 3
    Re: Beolit 707
    I have own the radio since new - no chance of an "adjustment"
  • 04-02-2009 5:04 AM In reply to
    Re: Beolit 707
    Antenna (tip) has been replaced ?
    Normally this is black on black beolits and silver on silver beolits (not that that explains the serial number...).
  • 04-02-2009 8:10 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beolit 707
    I noticed that too.
    Maybe it's just worn off the black color.
    I'm sure that the first Beolit 707 didn't carry serial number 1 so there must be another explanation.
  • 04-02-2009 8:33 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Re: Beolit 707
    Maybe the person responsible for setting the serial number machine during manufacturing had an early lunch break?Big Smile
    ...or he wondered what the counter machine's red button did!!
    If you think nobody cares, try missing a couple of payments.
  • 04-02-2009 11:04 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beolit 707
    "...or he wondered what the counter machine's red button did!!"
    LaughingLaughingLaughing
