Thank you Piet.
I tried different USB ports and turned the beo5 off before I docked it on the charger. Still nothing... I even uninstalled the driver and re-installed. Again, the beo5 seems to be working perfectly with windows xp; shows up everytime I connect, but for some reason the configuration tool doesn't recognize it is hooked up. Does the tool only look for certain USB ports? I have it hooked into a USB hub.
Also, since I have SW1.20a do I neeed a certain version of configuration tool (ex:1.00, 1.30, 2.20)?
Diggs
