Hi there !
i have BeoSystem 3 with number of units connected into it as follow :
Sky HD, BeoCentre 2, Mac Mini, Wii, Playstation 3, Samsung SAT receiver. it was ok before i bough BeoSound 5 and i bumped into the fact, that i have no spare input to connect it. i was trying back and force and the only solution i found is to connect bot game consoles Wii and PS3 to the same channel, via different type of cables. PS3 use HDMI socket and Wii uses normal plugs , so i plugged them both to AV5 .
Now, the question is, can i program macro command for Beo5 remote control unit, to switch input settings for AV5 on my BeoSystem 3, while i choose either one source or other , on the fly.
can anybody help me to know the truth ??
thank you,
Vladimir
