Hi
Is Beolab 7.4 a mono or stereo speaker, if is mono can you use as the only speaker with good results.
Søren
Hi Soren,
the beolab 7.4 is designed as a center speaker and therefore mono.
Only with the beolab 7.4 You will not have good sound with Your beovision.
Best regards
beorebels
You will need a pair of stereo speakers either side if you want to use the BeoLab 7-4. BeoLab 3s are ideal as they share a similar sound and the acoustic lenses work together nicely...
Weekly top artists:
