I have now checked the SMPS board, but so far there is no conclusive result. I had to unsolder the two flat cables that connect the board to another board (looks like the main processor board), both ends are soldered.
The schematics for the 81xx and my model seem to be quite similar. There are some differences in the components (my power driver FET seems to be a more recent model, for example), but the numbering seems to be almost identical. Too bad there is just a block schematic and not a detailed one.
I've measured all discrete semiconductors and found no faults so far, except the MOS driver (an STH7NA90FI) which seems to be damaged. The Drain-Source diode at first behaved like a capacitor under the DMM, then after shortening the leads it tested normal. That puzzled me much. The component is not readily available any more but I found a guy who will send me some and I'll change it for a test.
The SMPS behaviour is strange, it tries to start but there is no voltage on most of the secondary circuits, except one which measures about 11V. The feedback circuit has no power or very little, say 0.5V, and there is no signal at the optocouplers. TR12's emitter, that's the Q responsible for overload protection on the primary side, goes up and down with a frequency of about 1 Hz. There is some very high frequency ringing on the coil, but I can't trigger the signal correctly on my oscilloscope as it's only intermittent. The frequency also seems too high for normal SMPS operation. The caps on primary and secondary seem ok.
My best bet currently is the power MOSFET. It's too bad that there is no detailed schematic; should, for example, an SMD transistor or diode be blown I wouldn't even know the type or polarity. There are also no voltages labeled on the PCB so it's a lot of guesswork, especially as this SMPS is quite complex with all the PFC and protection stuff.
If anybody has additional ideas, please let me know. Kind regards, Leo
