Latest post 07-09-2011 2:22 PM by Beobuddy. 3 replies.
Page 1 of 1 (4 items)
  • 03-26-2009 5:37 PM
    • marfa
    • Not Ranked
    • Joined on 03-23-2009
    • Sissach
    • Posts 5
    using my Beovision6-26 as display for my MacBook 12"?
    hello,
    I tried to set up my beovision 6-26 as external display for my Apple Mac book 12". I connected the laptop tp the DVI connector of the beovision and of course selected "PC" with my Beo4. But then nothing happened. The "Help" menu of Apple were also not truly helpful.
    Has someone a tip? or a link / url where I could get further information?
    Your help is very much appreciated as always.
    M.
    Filed under: ,
  • 03-27-2009 10:41 AM In reply to
    Re: using my Beovision6-26 as display for my MacBook 12"?
    Hi M.:
    You have to setup the connection. In the setup menu of the BV you have to choose DVI-I in the PC connection (AV3).
    Regards.
    Jq. BS4 BL3 A8 Form2
  • 07-09-2011 2:18 PM In reply to
    Hi there,
    A late post I know...
    I have the same problem and can not for the life of me get the DVi to work.
    Can you shed any more light?
    Many thanks,
    GB
  • 07-09-2011 2:22 PM In reply to
    If I'm right, correct me if I'm wrong, you will need the hd-ready kit in your screen.
    Supllied by the dealer to make things work.
    It has to do with hdcp, otherwise you will not have any picture.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
