I recently started having a strange tuning problem on my BM8000.  I programmed the presets in frequency order (P1=88.9, P2=93.7, P3=94.1, etc).  When the BM8000 is off and I press one of the presets the system turns on and is tuned to that frequency.  BUT, if I press the preset for 88.9 I get a non-tuned frequency hum, like it's between stations.  If I turn the tuning dial no stations will tune in.  I have to turn the system off, press a different preset, then I can select the preset for 88.9 and it works fine.
If the system is off and I press any other preset, the system turns on and is tuned to that frequency and I can listen to that station.  If I reprogram the presets so that 88.9 is not P1, I still get the same result, it will not tune in.  Whatever preset 88.9 is set to, the system turns on but will not tune to that station.  I have to press a different preset, then I can press the one for 88.9.
I have tried setting the Tuning between Auto and Manual and it makes no difference.
Ideas?
