Latest post 04-01-2009 1:05 PM by nobby. 22 replies.
Page 1 of 1 (23 items)
  • 03-24-2009 6:04 PM
    broken master control panel (av9000) need alternative
    Removal men dropped my master control panel for my beosystem av9000 – now on ebay for spares or repairs L
    Looking for a change – I understand I need a mast link combatable device ??
    Will any B&O systems do, which to connect to TV via masterlink and share speakers (8000’s and 6000’s connected to TV)
    i.e. beoseound 3000, 3200, 9000
    thanks
  • 03-24-2009 6:32 PM In reply to
    Re: broken master control panel (av9000) need alternative
    I think it depends on which type of AV9000 you have - the early ones seem to have a slightly different type of Masterlink socket. In principle, a masterlinked audio system should be fine though.
  • 03-25-2009 5:52 AM In reply to
    The later systems used the Ouverture i think... i would not buy another masterpanel, since the masterpanel will not work stand alone.
  • 03-25-2009 9:35 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Every audio system should work with AV9000. I had a BC 9500, a BS7000 and a MCP 9000 connected to my AV 9000. And it`s the old 2way version.
    You will need a Beolink converter (AV9000-audio kit - 1610 or maybe 1611) for audiosystems without ML.
    Stefan
  • 03-25-2009 1:58 PM In reply to
    • Spiros
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Peter, remember we had the same discussion a few months ago. I have the oldest version of AV9000 and it was linked with my Beosound 4 with no problems at all. In fact it was connected to the rest (and still is) to the whole link in the house and no problems at all!!
    Best regards
    Spiros
  • 03-25-2009 3:31 PM In reply to
    thanks for the replies
    really like the beo4 but not sure about the price ???
    as suggested may just go an get another master panel - one on ebay.
  • 03-25-2009 5:42 PM In reply to
    • Henri
    • Not Ranked
    • Joined on 02-15-2009
    • Posts 66
    • Gold Member
    I'm not sure if you got the email I tried to send you a while ago, but I've got one extra master panel, stashed away "in case I need it someday". It should be 100% working (have to check that...) and it seems that I don't have use for it for now.
    Make me an offer, anything reasonable will probably be ok. Smile
  • 03-25-2009 8:13 PM In reply to
    • benjnz
    • Top 150 Contributor
    • Auckland NZ
    • Posts 392
    • Gold Member
    Spiros:
    OH? Mine's type 4305 with sw1.1 so would that work by un-plugging my BL3500 and plugging the AV900 into my ML of Avant RF DVD & BS3200?
    I tried it and I got Radio, A.Tape & CD which is cool but the only issue I have is what do I need to get my STB playing from the Avant to the AV9000 in my bedroom? Would it be worst case scenario get a STB controller fitted? If so are there any MX ones in existence?
  • 03-26-2009 3:56 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi there. I'm not sure if it is a matter of the stb. I guess that you have your Avant as a Video Master. Have you already installed the RF modulator which distributes the video signal from the Video Master to the rest of the linked TVs in the house?
    Best regards
    Spiros
  • 03-26-2009 5:43 PM In reply to
    • benjnz
    • Auckland NZ
    • Posts 392
    • Gold Member
    Errr, well I used to have a set-up of non B&O tv and BL3500 in the link room so that was fine to watch sat & DVDs, but now with the AV9000 I can get audio sources, just not sure how to get the DVD & SAT source from the Avant? And as it was a non B&O tv I had the modulator or some setting on rather than the default off Huh?
    Do I need something else like Beolink Video?
  • 03-27-2009 3:42 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Maybe this was a third party modulator? For such an installation you definetely need the B&O RF modulator, provided of course that you have already made the cabling which means that all antena cables from link rooms are going to the modulator where your video master is.
    Do you have such an installation?
    Best regards
    Spiros
  • 03-27-2009 5:50 AM In reply to
    • stefan
    • Posts 1,733
    benjnz:
    Set your BL 3500 to option 4 (L.OPT.4) and you can control all your mainroom devices, audio and video by pressing LINK - SOURCE.
    Store your link-frequency of the Avant to TV, channel 1 to the AV9000.
    To watch a DVD from the mainroom, you have to press TV (1) and LINK-DVD. You will get the picture and sound (mono) on your AV9000, and sound (stereo) via the BL3500. It´s the same with all video-sources of your main room.
    Hope this helps.
    Stefan
  • 03-29-2009 4:03 AM In reply to
    • benjnz
    • Auckland NZ
    • Posts 392
    • Gold Member
    Hey thanks Stefan Big Smile
    Yeah I've got it set-up now, but was just wondering if there was a way of getting the Avant sources on it so I can use the BL3500 somewhere else in the house that's all?
    On the fun side just got a MX7000 with motorised stand for $375, so my query would be do I just need an ML - Datalink convertor or a videolink, etc?
    Thanks,
    Ben (Confused of Auckland) hehehehe Stick out tongue
  • 03-29-2009 5:54 AM In reply to
    Hi
    Not sure of your location, but contact neil briffet at beovisions(ebay name) as i know he has a couple for sale here in the uk.
    I think he's called nobbyhall on beoworld, but i'm sure someone will correct me if I'm wrong.
    Regards Brett
  • 03-29-2009 8:27 AM In reply to
    • stefan
    • Posts 1,733
    benjnz:
    Thanks,
    Congratulations, yes, a Beolink Video 1615 should do it. you can use your MX as a link-TV for both audio and video.
    Stefan
  • 03-29-2009 4:52 PM In reply to
    Yes, I have two master panels here for AV9000 ... special price to Beoworld members :)
    Neil
    I also have a 1610 convertor for sale.
    Neil
  • 03-30-2009 12:12 PM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    nobby:
    Neil
    If I connect an AV9000 (the tv, not the Master Panel) to a Beosystem 7000 (with passive speakers) via a 1610, will I be able to route the TV sound to the beomaster by pressing "av" + "tv"
    At present, I have a bs7000 with passive speakers and an LX4500, and I always route the tv sound via the beosystem - I never use the tv's internal speakers. Will a 1610 allow me to use an av9000 in the same way as I use the LX in my current setup?
  • 03-30-2009 4:14 PM In reply to
    • stefan
    • Posts 1,733
    Yes  - will work. I used AV - TV ( or -SAT. -V.TAPE. V.AUX...) to get stereo sound in video linkrooms with MX4000s.
    If I remember correctly, the 1610 converter only works with the older, 2way AV9000.
    Stefan
  • 03-31-2009 3:38 PM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    stefan:
    Stefan
    Ah, thank you! My plan is to get an old 2-way AV9000 (and a 1610, of course), but I wanted to check first that it would work the way I want it to - b&o's literature only mentions setups with active speakers, and I have passive speakers.
  • 03-31-2009 4:49 PM In reply to
    Yes, the 1610 will allow you to connect the AV9000 to the BS7000.
    Neil
  • 03-31-2009 5:01 PM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    As long as it allows me to use the av9000 in the same way as I use my LX (ie routing the tv sound to the bs7000's passive speakers via "av" + "tv"), I'm satisfied :-)
    Neil, how much is your 1610?
  • 04-01-2009 1:05 PM In reply to
    £30 plus the postage.
    Neil
