1st March February 2012
Latest post 05-20-2009 4:02 AM by k984942. 6 replies.
03-23-2009 6:33 PM
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
Hi All,
I have a DVD1 that I'm very happy with. The only problem is, when I finish watching a film and switch to Sat (my Virgin Box) on my RF Avant, the sound does not come through but the picture does. I've noticed that if I switch off the Avant (and the DVD1 then switches off) then back on again, the sound and picture from my Virgin box both come on.
I can only conclude the the silence problem must be because the DVD1 is still on and passing a silent sound signal via the digital Coax.
Therefore, does anyone know how to switch off the DVD1 via the Beo4 without switching my Avant off?
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
k984942
- London, UK
- Posts 194
Re: Switching off a DVD1?
Am I the only one with this problem?
Am I posting my question in the wrong way?
Please guys, any help would really be appreciated
BMGHB
- Joined on 05-12-2007
- Posts 219
Its the first time i hear something like this.
Is there a digital coax cable from the DVD1 to the DSS input on the avant?
Is there a digital coax cable from the virgin box to the DSS input on the avant?
Is the problem the same if you remove this cable?
To my knowledge there is no way to manually switch of a DVD1.
BMGHB
BeoVision10-46MKII,BL3,BL2,BS8,Beo5
k984942
- London, UK
- Posts 194
Hi there,
There is a digital coax between the DVD1 and the Avant but not between the Virgin box and the Avant. This problem only started after I fitted the coax cable - everything was fine when sound was coming over the SCART.
Since I've already invested in the Coax cable I don't really want to have to remove it and go back to just SCART just to fix this problem.
Any alternative suggestions would be great.
k984942
- London, UK
- Posts 194
Anyone? Surely I can't be the only one with this issue!
Any help / advice would be gratefully received.
Cheers
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
You can press and hold down the red circle button on the DVD1 to manually switch it off, but then you need to get off your seat to do this. It seems the cable you bought is interfering with the setup. You might have to go back to Scart......
My B&O: 2009 Catalogue and Pricelist
k984942
- London, UK
- Posts 194
I was worried that might be the case.
I really would have thought B&O would have thought things through a little more thoroughly than this. After all I am using a B&O TV and B&O DVD player to ensure that things work properly together.
Very annoying!
Page 1 of 1 (7 items)
