Latest post 03-26-2009 5:40 PM by ergonomist. 3 replies.
Page 1 of 1 (4 items)
  • 03-23-2009 1:24 PM
    Beosound 3200 Remote Control
    Hello, I'm new to the website and also to B&O ownership, having just had my birthday for which my wife purchased me a Beosound 3200 and Beolab 6000s.
    I was wondering if the Beo 4 remote is the only one which works with the Beosound 3200, or does the older Beolink 1000 remote work? I know someone who has an unused Beolink 1000 and thought it may save me purchasing the Beo4. Is the functionality the same etc.
    I mainly want to use it for volume control, being lazy from the other side of the room!
    Hope someone can put me right.
    Thanks,
    Lee
  • 03-23-2009 2:14 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beosound 3200 Remote Control
    Welcome first off,
    I was in the same situation you are in right now, but with a BeoMaster 4500. I was looking for a BeoLink 1000 but I couldn't find one that was reasonably priced, or find one at all for that matter. However, most times I found that the Beo4 (new) was actually competitive in pricing with the BeoLink 1000. I was able to get a Beo4 for around $160, which was right with the BeoLink 1000. My advice is get the BeoLink 1000 if its cheaper but the Beo4 is completely worth it at the same time. I am completely satisfied with the Beo4 and I'm sure you would be too. Especially if you have a brand new system, I personally would get the Beo4, its not that much more.
    -Ev
    Evan
  • 03-23-2009 2:18 PM In reply to
    Welcome to the forum, Lee. You apparently have a very nice wife Laughing
    The Beolink 1000 and Beo4 send mostly the same codes, so you can use either one for day-to-day operation with no problems (volume, channel, source select, CD track, etc). Some functions may be a bit more awkward with BL1000, requiring you to press shift+something, not clearly marked on the buttons. This will also depend on the exact version of BL1000 you get. But try it first, I think you'll be quite happy with it.
    -mika
  • 03-26-2009 5:40 PM In reply to
    Many thanks for your help, I give it a try and see how I get on.
