Latest post 03-27-2009 5:17 PM by Knubbi. 8 replies.
Page 1 of 1 (9 items)
  • 03-22-2009 6:37 AM
    BV7 Software version
    Hi all
    I have a mk2 bv7 that I need to find the software version of... I know how to go into service menu but from there I am lost... can anybody point me in the right direction...
    thanks
  • 03-22-2009 7:23 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: BV7 Software version
    Hi
    Press menu, go to Options and press Red + Go. In the next menu, you can see SW option. Press Go and the SW Version will appear.
    Quim
  • 03-22-2009 7:54 AM In reply to
    Thanks for the reply.. under the service menu I get ap sw: 7.0 & a few other fields.
    Am i looking at the correct field?
  • 03-23-2009 1:44 PM In reply to
    Anyone.. is ap sw the correct field for the version of software my bv 7 is running?
  • 03-23-2009 2:05 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Last version for your TV is AP SW 7.7; M2 SW 7.74; TV SW 7.84
    Regards
    Quim
  • 03-23-2009 2:29 PM In reply to
    Thanks quim
  • 03-26-2009 7:36 PM In reply to
    What is the current software version for BV 7-40 MK3, please?
    Cheers, Knubbi -- Beovision 7-40 MK3, 2x Beolab 5, 2x Beolab 8000
  • 03-27-2009 5:44 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    Knubbi:
    5.08a
    Quim
  • 03-27-2009 5:17 PM In reply to
    Thank you. I was confused as there are so many version number in the user config menu, service menu, etc.
