Latest post 03-31-2009 3:26 PM by birgerbum. 2 replies.
Page 1 of 1 (3 items)
  • 03-21-2009 8:51 PM
    Beogram CD 50 Problem
    I recently purchased a used Beogram CD 50 to complete my 5000 system.  I purchased it as-is and the only problem so far seems to be a sluggish tray mechanism.  Many times the tray does not have the power to properly load the cd without some help.  I see a rubber belt in the mechanism and I assume that like the Beocord it needs to be replaced.  Does anyone know of a good source for these?  I purchased my Beocord belts from Martin and they worked flawlessly, if he's checking the forums, do you also have any replacement belts for the Beogram?
  • 03-21-2009 9:00 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram CD 50 Problem
    Yes Martin can supply a belt for this but another contributary problem will be dried grease in the loading tray mechanism. You need to strip it down and clean off the old grease and replace with fresh silicon grease.
    Chris.
  • 03-31-2009 3:26 PM In reply to
    Hi
    it's often the dc motor that causes the trouble try to carefully lubricate the bearings
    use only sewing machine oil
    regards
    jan
