Latest post 03-23-2009 12:21 AM by ducha. 4 replies.
Page 1 of 1 (5 items)
  • 03-21-2009 8:27 PM
    • ducha
    • Not Ranked
    • Joined on 01-04-2008
    • Wisconsin, US
    • Posts 77
    Beogram 6500 dust cover
    Hi guys,
    I have been searching for a nice Beogram 6500 turntable to complete one of my Beosoystem 6500s. I have noticed that several of the Beogram 6500s I have seen recently have dust covers that are sagging in the center at the back of the cover. Is this a common problem with these turntables?
    Thanks,
    Aaron
  • 03-22-2009 12:40 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Beogram 6500 dust cover
    Yes, I've seen several in that condition.  Have one myself.  Also applies to the Beogram 7000, which is the same turntable with a different label.
    Not sure why tho..
  • 03-22-2009 4:42 AM In reply to
    Hi Aaron,
    My Beogram 7000 has exactly the same issue. I've heard it said that if you take the cover off and put it in a bowl of hot water with a weight on top, the problem can be solved. Not sure if this works, though. I don't have the guts to try this.
  • 03-22-2009 5:27 AM In reply to
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    All Beogram 7000 record decks seem to have this problem. I tried the hot water & weight procedure, but with no result.
  • 03-23-2009 12:21 AM In reply to
    • ducha
    • Not Ranked
    • Wisconsin, US
    • Posts 77
    Okay thanks guys,
    This is probably something that I will just have to deal with if I ever find a BG 6500!
    Aaron
