Latest post 10-14-2011 3:24 PM by Blackrix. 7 replies.
Page 1 of 1 (8 items)
  • 03-21-2009 6:09 AM
    • scuba
    • Not Ranked
    • Joined on 12-28-2008
    • Posts 48
    Wallmounting Beomaster 1200
    Hi,i have seen a  picture of a Beomaster 1200 mounted on a wall,does anybody know how this is done? there are two stands underneath the BM ,ment for tilting  it slightly forward,is it ment to hang from these evenualy from some of the skrews in the chassis?ore did it come whit some kind of  custom wallmount from B&O
    Jon
  • 03-21-2009 10:53 AM In reply to
    Re: Wallmounting Beomaster 1200
    You need a wallmount. Don't try to hang it on the stands, as this will certainly break them!
    I owned several 1001s (thats the FM-only version of the 1200) and once made a custom wallmount for one of these.
    It's not that hard; you just need four pieces of metal to screw on the chassis and the correspondent mountings on the wall.
  • 03-21-2009 11:53 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I never owned an original wallmount of this type myself but I believe it is
    more or less a flat metal plate, bolted to the wall.
    The Beomaster grips the plate using the little grooves on the sides of
    it's square plastic feet. It's hung on the plate like a painting on a nail in
    the wall.
  • 03-22-2009 6:15 PM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Ok,thanks , a sheetmetal mounting bracket sounds like a good idea and, its easy to make,now my only problem is to find 90 degre angeled 5 and 2 pin Din plugs to awoid the speaker and signalkabels sticking upp from the BM.
    Jon
  • 03-23-2009 5:29 AM In reply to
    Hi!
    My first piece of B&O was a beautiful BM1200, which came with original BV1200 speakers and... the original wallmount thingy! Only 35 euro's Laughing
    It is a metal frame that slides into the little slots in the rubber/plastic paws (good english?) that are used when standing horizontal, flat on the table.
    On this frame you can click a silver/alu colored brace-something that will hide the cables out of sight.
    I'll try and make a picture of it if you like, the beomaster is at my mother's house right now so might take a while.
    A sheetmetal plate that slides into the little slots should do the trick too, maybe even better.
  • 03-25-2009 4:24 PM In reply to
    • scuba
    • Not Ranked
    • Posts 48
    Hi,a picture would be very helpfull, maybe i can make a copy of the original wallmount,in brushed or polished stainless steel
    Jon
  • 10-12-2011 1:24 PM In reply to
    Pics of the wallmount system, for future reference:
    http://forum.beoworld.org/forums/p/33237/274828.aspx
    Yes -  thumbs up
  • 10-14-2011 3:24 PM In reply to
    Premiumverum:
    Yes -  thumbs up
    The one in this topic is for BeoMaster 1001. This is the same wallmount, the difference is that the topplate for BeoMaster 1200 is grey. I have seen the original one for BeoMaster 1200 somewhere in the north of the Netherlands and the original one for BeoMaster 1001 is still new in the box at my home....... Stick out tongue
