1st March February 2012
Latest post 06-02-2007 8:51 PM by Jandyt. 17 replies.
05-28-2007 2:57 PM
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Is this quadraphonic or glorified stereo?
Most of you know I have recently wired in my new 8000s as rear to my Pentalab/Avant setup. Nah then, When I watch a DVD that is recorded in 5:1 surround sound but press Speaker, 4 so the centre speaker(Avant) isn't functioning. Is this quadraphonic or enhanced stereo? ie same on rear speakers as the front. Andy T.
Coolskin
- Joined on 04-16-2007
- Holland
- Posts 505
Re: Is this quadraphonic or glorified stereo?
Andy T, the latter. The stereo on the front is the same as on the rear speakers. Nice to use during a party when low volumes don't fill the room, and an extra set speakers can help. Otherwise IMHO the speaker 4 mode is useless.
Tom
- Luxembourg
- Posts 3,175
right. quadrophonic is a surround setup with 4 independant channels. speaker 4 mode is, as coolskin sait enhanced stereo, where the front and the rear channels are the same.
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Jandyt
- Posts 13,004
Thanks to both of you for your replies. For the last 14 years, I've beeen watching TV in stereo with my Pentas. It takes a lot of getting used to hearing sound from the TV. Over the last two or three weeks I have been trying my new set up in diferent ways and I must admit that I don't like the 5 speaker setup for regular TV programs. I have been mostly leaning towards speaker 4. Am I abnormal? Is this normal behaviour? Does any body else feel the same? Andy T.
Tom
- Luxembourg
- Posts 3,175
My audio setup is BL7.1; BL8000; BL6000, and for normal TV, I normaly use speaker1. Speaker5 can be ok for movies or TV-Shows, but I never use speaker 4 for TV, neither speaker 2. Don't want to say you are abnormal, but I to me it is strange to use speaker4 for TV.
Coolskin
- Holland
- Posts 505
jandyt: Thanks to both of you for your replies. For the last 14 years, I've beeen watching TV in stereo with my Pentas. It takes a lot of getting used to hearing sound from the TV. Over the last two or three weeks I have been trying my new set up in diferent ways and I must admit that I don't like the 5 speaker setup for regular TV programs. I have been mostly leaning towards speaker 4. Am I abnormal? Is this normal behaviour? Does any body else feel the same? Andy T.
The BV7 we have is flanked by a set of BL4000. Before the sw upgrade the Video was set to ALL front speakers. Now with sw 6.3 we can select also speaker 1 mode. For regular TV this is the most setting used.
For DVD I switch manually to 5.1
soundproof
- Posts 2,340
My surround processor automatically detects when a TV-transmission is in 5.1 or stereo and switches accordingly. So I can't say I'm in a fixed mode. It's kind of strange when I channel surf though, as the sound perspective will shift from channel to channel! Jazz or classical is often transmitted in surround today, I always switch those manually from 5 to 2 speakers, but that's just because I'm a curmudgeon.
As to your original question: In quadraphonic there would be four different microphones recording four different vantage points for the performance - these would then be recreated with four distinct signals through four loudspeakers. What you have done is duplicate a left-right signal to spread the music. Good for background listening. Here's an illustration of the original quadraphonic theory, illustrating areas where the ears have acute frequency awareness and where this drops off. I'll take the time one day to use this is a starting point for why one should never have speakers in the back as powerful as the ones in front if perceived verisimilitude is the goal. As to glorified stereo ... I'd call it muddled stereo. Glorified stereo would be if you had a properly calibrated center channel delivering a processed center channel signal from the L-R sources. The BeoSystem 3 does a good job of that.
Tom
- Luxembourg
- Posts 3,175
soundproof: My surround processor automatically detects when a TV-transmission is in 5.1 or stereo and switches accordingly. So I can't say I'm in a fixed mode.
My BV7 does the same; SW 6.3
Jandyt
- Posts 13,004
Wow! Is there no end to the knowledge and wisdom of Beoworlders? Thankyou all for your replies. Andy T.
Coolskin
- Holland
- Posts 505
tom: soundproof: My surround processor automatically detects when a TV-transmission is in 5.1 or stereo and switches accordingly. So I can't say I'm in a fixed mode.
Mine does too, except when the speaker 1 is selected in the VIDEO menu. Then the speaker setting stays put, and never changes.
Try it for your self. If your TV does automatically selects 5.1 during DVD playback please reply.
Tom
- Luxembourg
- Posts 3,175
Coolskin: tom: soundproof: My surround processor automatically detects when a TV-transmission is in 5.1 or stereo and switches accordingly. So I can't say I'm in a fixed mode.
My default video sound setup is speaker1, but when a programm is in 5.1, the BV automatically switches to speaker5 modus, but only when watching TV, not when playing a DVD. Not sure if this is what you meant.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Advice from a reet Northern lad - divn't do it! Stereo is stereo - the only way to listen - turn off the rear speakers
Tom
- Luxembourg
- Posts 3,175
Puncher: Advice from a reet Northern lad - divn't do it! Stereo is stereo - the only way to listen - turn off the rear speakers
Speaking of music you are absolutely right, but not for movies. I think that is what you wanted to say ,or???
Puncher
- Posts 9,588
tom: Puncher: Advice from a reet Northern lad - divn't do it! Stereo is stereo - the only way to listen - turn off the rear speakers
why aye man! - arnie fur music!
Tom
- Luxembourg
- Posts 3,175
Puncher: tom: Puncher: Advice from a reet Northern lad - divn't do it! Stereo is stereo - the only way to listen - turn off the rear speakers
sorry puncher, but my english slang is not that good. what did you say?
Puncher
- Posts 9,588
tom: Puncher: tom: Puncher: Advice from a reet Northern lad - divn't do it! Stereo is stereo - the only way to listen - turn off the rear speakers
Of course my Good Fellow! - only for music!
Tom
- Luxembourg
- Posts 3,175
Puncher: Of course my Good Fellow! - only for music!
I should have known!
Page 1 of 1 (18 items)
