Latest post 09-24-2011 11:12 AM by Tony. 42 replies.
Page 2 of 2 (43 items) < Previous 1 2
  • 03-29-2009 4:39 PM In reply to
    Re: Urgent help needed!! With mx7000
    it cannot be preset in a position but the beo4 will make it turn
    No way to tune the channels
    The serial number states that it is a beo4 model set! is the sticker on the back the only place the serial number is found?
  • 03-29-2009 4:44 PM In reply to
    What happens if you send the picture command from the Beo4 in the V.setup menu?
  • 03-29-2009 5:12 PM In reply to
    nobby:
    sorry to sound stupid not sure what you mean?
  • 03-30-2009 9:20 AM In reply to
    Add V.SETUP to your LIST button on your Beo4 remote.
    The go to V.SETUP sub menu and you will find TUNE, PICTURE, TREBLE, BASS etc.
    Neil
  • 03-30-2009 12:32 PM In reply to
    Thanks Neil!
      Do you have any idea why there is a line of distortion and when a dark picture with light areas it flickers??
    Cheers Nick
  • 03-30-2009 3:03 PM In reply to
    Photograph the problem for me, so i can see what you mean.
    Neil
  • 03-30-2009 3:26 PM In reply to
    I will try but the line that distorts is very hard to capture  The other issue should be a bit easier
    Cheers Nick
  • 08-09-2009 11:30 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Hi all -Mr Stupid here
    Tried the aforementioned setup's cannot get em to work, my setup;_
    av1   - b&o v8000 v-tp with a sky box and a set top box daisy chained
    av2   - b&o dvd1
    i am in france , the tv is a pal uk std(about 1997 with earlier set up system) so no external aerial, can link sky thro rf system but the set top box is french secam so it won't work however when the b&o vcr taken out of the equation everything works fine
    how do i call up or set the vcr to read the scart input from sky - cannot find a link or info
    have also tried with a later mx7000(2002 with the later setup system) with a secam rf channel same result
    help please
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 08-09-2009 12:07 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    "how do i call up or set the vcr to read the scart input from sky - cannot find a link or info"
    V.MEM (V.TAPE) - Yellow...(?) If I remember correctly this works with HDR1/2...
    Stefan
  • 08-09-2009 1:01 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    hi there
    nurse says i can take the boxing gloves off if i really try to use the beo4! - always been a bl1000 man! - i'll give it a whizz later
    t
  • 08-09-2009 1:57 PM In reply to
    • stefan
    • Posts 1,733
    On BL1000 try: V.TAPE - SHIFT - RIGHT
    Stefan
  • 08-10-2009 11:09 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    stef
    Tried both your suggestions ie beo4 and bl1000 - neither worked! - only paged the inserted video - took it out, nothing
    Have tried the V8000 menu-setup route now get the sky input on ch 1 & 2 however with menu overlaid when i go back to pure vtape can't find ch1 or 2 - how do i get em up - sorry for being a dimwit - can usually sort most things but this oy vay!
    cheers
    t
  • 08-10-2009 5:04 PM In reply to
    • stefan
    • Posts 1,733
    "Have tried the V8000 menu-setup route now get the sky input on ch 1 & 2 however with menu overlaid when i go back to pure vtape can't find ch1 or 2 "... Sorry, I don`t know what you mean....(?)
    If your sky box is connected to the AUX input of the V8000 it should be possible to select this input by CAMCORDER in the main menu of the V8000. You will find this information in the user- and setup manual - hope this helps.
    Stefan
  • 08-11-2009 2:08 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    have been playing around this afternoon to no avail - i did have decoder sound at one stage but no pic tried both tv's ie early bl1000 and later beo 4 again no joy camcorder setting will not generate a pic - wondering if its the scart leads although they all work fine in other configs
    have to leave it a couple of days now as in transit to uk - will bring v8000 with me as i have mx7000 in uk house so can continue hair pulling etc!
    salut
    t
  • 09-18-2009 10:53 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Hi all
    WEhoopeeeee got my problem sorted - can now view sky box thro the v8000 into av1 and  with the dvd1 into av2.
    Melvyn B&O Solihull made a sort of sideways comment recently to try a scart to rca lead into the back or the vcr - didthat with a 2awitched 2 way plug ie in or out of the sky box and into thr R Y W on the vcr a little messy to set it up ie need to go into the vcr menu and select camcorder but it WORKS!!!! - the set up did not justify the expense of a new AV2 Expander box as it will be upgraded with a BC2 and a simple BV7-32(you may wonder why - i alresdy have the BC2!)
    Cheers from a happy bunny!
    T
  • 09-13-2011 12:03 PM In reply to
    • Tony
    • Not Ranked
    • Joined on 05-07-2009
    • Sweden
    • Posts 21
    • Gold Member
    How do you configure a preset to use decoder? I have a MX7000 from 1992 (early one with the BL1000 remote)
  • 09-14-2011 4:47 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Tony:
    As far as I remember in the tuning "menu" that is displayed after pressing "goto".
    Pressing "shift" and then "picture" will change "dec off" to "dec on" - you'll have
    to store the change in the usual way.
    Don't forget to make the required settings for AV1 or AV2 in the "setup menu"
    Filed under: , , ,
  • 09-24-2011 11:12 AM In reply to
    • Tony
    • Not Ranked
    • Sweden
    • Posts 21
    • Gold Member
    Thank you! :-)
    Before your answer I tried a lot of combination of shift and other buttons.
    But as it seems; never "Picture" ;-)
    Now it works fine.
    Then only little downside compared with "V-Tape 2" is that the MX does not start automatically when I start the DTV-decoder. But that is not important.
    Easy to just push "TV"
