1st March February 2012
Latest post 09-10-2009 1:07 PM by Peter. 20 replies.
03-16-2009 2:53 AM
kenoBy
- Joined on 03-16-2009
- Posts 13
Beovox MC 120.2 speaker stands
Hello everyone, it's my first post here and I would like to open it with a question that bothers be for quite some time, I have posted it on B&O forums few years back but with no answer.
I would like to get the speaker stands for my old MC 120.2 speakers or if anyone has a pair at home to give me dimensions so I can make my own, alternatively.
Thanks in advance for any answers!
[Edit] I'm curious about this one: "Author Notes:
These were extremely fine speakers with a superb sound and flat frequency response. They do suffer from foam rot and are hence very cheap these days. A replacement Peerless woofer is available or recone the original. Described to the author by a B&O insider as one of the best passive speakers made by B&O."
Which foam is the author taking about? And how to prevent it?
kenoBy
- Posts 13
Re: Beovox MC 120.2 speaker stands
Thanks, both for greets and the link.
It makes sense now..
kenoBy
- Posts 13
Thanks Mr Andy, I found it priceless, great job!
kenoBy
- Posts 13
Hi everyone, wasn't here for some time now. Hope all of you are doing fine.
I have bought a new amp for my 120.2 pairs. It's a NAD C372 and what I am wondering, out of your experience if this amp is ok for them, concerning the power output. On the speaker set it says 120W continuous load and 200W music load. Now, the Nad has 2X150W @ 8ohm continuous and IHF dynamic power at 8Ω 220W (23.42dBW)
Thanks.
kenoBy
- Posts 13
and:
I am very sad.... and to say I bought them over a friend is even more dissapointing...
Anyone selling a pair of these?
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
A very familiar story where people replace these drivers with so called "better" units only to be disappointed with the results. One of our members (jOhnbarker) replaced the bass drivers in his MC120.2's with some Peerless 830667 units of very similar specifications with good results by all accounts. It may well be worth taking a look at the thread and deciding if you think this would be worth doing, personally I would give it a go as these are wonderful speakers and it is very doubtful that you would find any original drivers so this could be a very good 2nd best.
Chris.
kenoBy
- Posts 13
Medogsfat:
I bought the speakers like this, have't done anything to them. I just noticed they are woooowing tad more than necessary. And looking at some photos here I noticed the visual difference.
Chris.
Thanks, will look into definetly. I will have to se where to get also the fire retardant acoustic foam to replace it with that scrap I found inside.
Medogsfat
- Posts 4,045
The foam looks original to me AFAIK.
Chris.
kenoBy
- Posts 13
I have seen the speakers from Mr. Andy, on the pictures from the thread he linked few posts up. Here is the photo:
http://forum.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.PostAttachments/00.00.03.82.02/P8120007.JPG
And the foam (actually sponge) has a heat burn from the coil on the circuit board, that is why I have a doubt.
Overall the speakers are not that bad, but the bass is really annoying me sometimes. I don't have an B&O impression if you get what I mean. Especially when I saw the woofers I am having inside it got somewhat clear to me why they do not sound so uniform.
Medogsfat
- Posts 4,045
You could both well be right, I've lost count of the different speakers of this era I've worked on over the years and all sorts of different damping materials have been used in them. Short of taking my MC120.s off the wall taking them apart I'll bow to your knowledge.
Chris.
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
Just to add my two penneth to this discussion:
The foam in your MC120.2s looks exactly the same as the foam I found inside my speakers when I opened them up. The shapes, colour and texture look exactly the same. I wonder if B&O changed the specs at some point in the production run though, as Andy seems to have something a bit different in his.
Those Peerless woofers that I bought are excellent. After a few weeks of light use they were eventually well 'played in', and I can thoroughly recommend them to you! The bass is a bit more up front than with the original woofers, but my old ones were knackered so it's hard to say what they would have sounded like had I bothered to refoam the originals instead.
kenoBy
- Posts 13
I could agree with Mr. Andy as from what I have seen from his photos and on the internet while googling that "fluffy", fiber stuffing is the correct one for these speakers. It doesn't take as much of volume as the sponge, atleast, as it is not as dense.
Also, as mentioned, the sponge is burned form the coil on the back of the mid-high enclosure. I doubt B&O would put something inside that is melting with the temperature increase. Most, if not all of this stuffings on the market are fire retardant.
That is just my opinion. Anyway, I doubt that distortion of the bass is coming from the sponge, it is just the cheap driver that is installed.
Thanks for your opinions guys!
Does enyone have a pair of those original drivers? Or knows someone who has them.
soundchoice70
- Joined on 08-07-2008
- Posts 201
Hi there,
Perhaps B&O changed the foam at the .2 update. My S80.2 have exactly the same yellow foam that yours has in them too, and I have seen other photos with the same foam (John's included) so i suspect it might be standard.
For drivers perhaps Martin (member Dillion) may be able to assist you.
Laurence.
kenoBy
- Posts 13
That's interesting, thanks for your info.
I ahve already contacted him (Dillon) but he doesn't have a pair.
Anyhow, if anyone comes across of a pair of those drivers, please contact me.
Thanks!
Peter
- Joined on 02-12-2007
- Posts 9,572
I replaced mine with Peerless drivers a long time ago and was happy with the results. Mine were S120s and can be seen with the new drivers here. Mine were a fairly unpleasant teak colour unlike the lovely rosewood that yours are. Mine had the tatty foam like yours - my older Beovox speakers have more of a blanket type filling.
Although these speakers do sound very good, the construction is nothing like as good as the slightly earlier but similar sized S75. The finish of the wood internally is very rough and I don't like the port arrangement at all. These late uniphase speakers are all like this though - cabinet making was no longer taken as seriously by B&O at this time!
Page 1 of 1 (21 items)
