Latest post 03-23-2009 4:27 PM by Alex. 12 replies.
Page 1 of 1 (13 items)
  • 03-14-2009 6:25 PM
    MP3 player issue
    Any idea why such a relatively low output from beocenter 2500 when connected to a reasonbly good mp3 player?
    Filed under:
  • 03-14-2009 6:35 PM In reply to
    Re: MP3 player issue
    Turn up the volume of the MP3 player...
    The race for quality has no finish line- so technically, it's more like a death march.
  • 03-14-2009 7:30 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Lol!
    I thought just the same when I connected my Beosound 2 to my 60s 5000 system! Was dissapointed until I found the volume control on the Beosound.
    My Kikinoko MP3 didn't have a volume control.
    Andy T.
    Poor me, never win owt!
  • 03-15-2009 10:59 AM In reply to
    any more intelligent technical advice please?...
  • 03-15-2009 2:44 PM In reply to
    It is true. Most MP3 players have a variable output and if not put to full voulme, the sound will be low. Some however have a special setting in the set up menu - the Sony ATRAC player has a full line output you can select. I would look at the MP3 player more than the 2500 - try another known line source if you are convinced it is the 2500. How are you connecting it? If mini jack to 5 pin DIN, have you the correct type of lead? There are both in and out leads so make sure you have the correct one.
  • 03-15-2009 3:23 PM In reply to
    Hi patroclos,
    Many MP3 players (including most Apple iPod models) have volume limiters built in to prevent the manufacturers being sued by customers who deafen themselves...... Laughing
    However, this does mean that the players will often fail to give sufficient output when connected to a home audio system, as they will not provide the voltage that the audio system is expecting to see (typically around 2 volts RMS).  As you haven't mentioned the type of MP3 player you are using, you may wish to Google the your MP3 player, followed by the words "volume limiter" to see if your player is affected.
    There will often be instructions on the net explaining how to bypass the volume limiter on your player.
    As Peter says, you also need to check that you have the correct cable, although an incorrect cable will normally give you no output rather than low volume.  Please get in touch with me if you need help finding the correct cable.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 03-16-2009 11:10 AM In reply to
    Thank you,
    the above problem occurs with the sony walkman NWZ-S639F.
    There is a setting for AVLS (automatic volume limiting system) but it makes little difference by switching it off: to get a decent sound the mp3 volume needs to be set at maximum (30) and the beocenter 2500 at more than 70 and then it starts to sound 'noisy'.
    Google search reveals no known method to crack any possible volume restriction on the sony nwz series (if there is one).
    I also tried to connect the 2500 with my pc soundcard and the  output is still inadequate, which makes me think it has to do more with the beocenter. The AUX line has 7 holes. Does it matter if my cable, illustrated below) is only 5 PIN?
  • 03-16-2009 11:43 AM In reply to
    Hi patroclos,
    You only need a five pin DIN plug, as the other two pins are for signalling to other B&O products.  I wonder if your cable is faulty?
    Assuming that the sound was turned up on your PC soundcard (usually about 75%), then you should get loud clear sound with a good cable.
    Let me know if you need a replacement cable! Yes -  thumbs up
    Best regards,
    Steve.
  • 03-23-2009 10:27 AM In reply to
    I would like to thank Steve because the above problem ended with the new cable I received today from 'Sounds Heavenly'!
  • 03-23-2009 10:31 AM In reply to
    Hi patroclos,
    Glad to hear your problem is solved!
    Best regards,
    Steve.
  • 03-23-2009 11:30 AM In reply to
    Very pleased to hear you have a result and well done Steve.
  • 03-23-2009 3:43 PM In reply to
    • Jandyt
    • Posts 13,004
    Yes -  thumbs up
    Nice one! Good on ya Steve.
  • 03-23-2009 4:27 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    FWIW, it sounds as though the problem patroclos was having was to do with the inputs and outputs being wired the wrong way round in his cable, a problem I've encountered before.
    If you wire an iPod (or any other source as a matter of fact) into the output part of a DIN socket as opposed to the input part, you will still hear the source, just very quietly and on all inputs! This is surprisingly easy to do as a lot of sources (esp. online) seem to refer to inputs + outputs the wrong way round. Confused
     Weekly top artists:
