Its not that difficult and you dont have to remove anything if I remember correctly.
take the top off, then open the draw. You can then clean the cogs of the mechanism with cotton buds and alcohol to remove the old grease. Then smear some new silicone grease on the cogs and I exprct it will be fine.
