Glad you've found a cable, jackdaniels413.
By the way, thanks for the mention Chris!
For any other Beosound 1 owners wanting to connect an iPod/MP3 player to the Aux socket, it is worth noting that you need to press the two arrow keys either side of the <CD> button simultaneously to activate the Aux input.
And yes, I can help if you need a cable!
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
