ah ha! It's not the problems I'm having, more like the problems I will be having.
I'm
trying to get my hands on a broken (in some way) Beocenter 9000 (Lee's
helping me with this) to convert into, I suppose for a better term,
digital media centre. I'm hoping to stick a small form factor
motherboard and bit's and pieces inside the case and with any luck keep
most of the audio circuitry as well. However, I want to use the
controls and display (or some of them) with the pc.
So you see
apart from committing B&O sacrilege (well using a broken one shouldn't be so bad) I'm setting my self a rather
difficult task so any info will be more than welcome!
Rob
