Latest post 03-25-2009 3:22 PM by Knubbi. 2 replies.
Page 1 of 1 (3 items)
  • 03-10-2009 4:44 PM
    Activate Front Row using V.AUX?
    Hi All.
    Is there a way to use the v.aux command to activate Front Row? I have it working with the PC command, and I tried changing the "PC" command in the FrontRow.scpt to "V.AUX" but that does not work. Will the program recognize the V.AUX in any way?
    Thanks!
  • 03-19-2009 2:58 AM In reply to
    Re: Activate Front Row using V.AUX?
    I think it's possible, check if the command V.AUX is the correct one to use. In some cases you have to use the actual number instead. (for example L-V.AUX = 130. I'm using this command to activate EyeTV)
    if command is 130 then ....
    TIP: If you want to see which IR-code the BeoPort is receiving add the following code in the FrontRow-script:
    In the end of the IrCommand()
    return {source,command,linkbit}
    Then you can see all the IR-codes in the SystemEvents
  • 03-25-2009 3:22 PM In reply to
    I would be very curious to learn more about what you talk.
    Are all key presses on the Beo4 passed to the Mac via IR? Can you program different actions depending on which key is pressed on the Beo4.
    Would you have any advice for further reading/study?
    Cheers, Knubbi -- Beovision 7-40 MK3, 2x Beolab 5, 2x Beolab 8000
