Can you replace it yourself ?
If the chip in your Beomaster is a STK 463, I have one.
Actually, the one I have is a STK 465 but that only means
you will get 5 Watts more per channel.
Edit: Oh yes, there are some available at Ebay. Make sure to get the correct physical outline.
