Latest post 03-10-2009 1:50 PM by ouverture. 4 replies.
Page 1 of 1 (5 items)
  • 03-10-2009 9:21 AM
    MCP5500 and Radio Presets
    I remember how to use my Beolink 1000 remote to program radio station presets on my BeoMaster 5500
    press Go To  xxx.x  ( for the FM station frequency )
    press Store  -  then type in a preset number ( between 1 and 20 ) and
    press Store again
    but I can't remember how to do it using the MCP 5500, can someone refresh my failing brain, thanks :-)
  • 03-10-2009 10:27 AM In reply to
    Re: MCP5500 and Radio Presets
    Tune to the channel you want; press Preset on the secondary panel and the first free preset will flash. If you want a different preset number, key in the number, then press Store!
  • 03-10-2009 11:06 AM In reply to
    thanks Peter for the heads up, do I use the wheel to tune into a radio station, because when I do that the volume goes up and down   :-)
  • 03-10-2009 12:18 PM In reply to
    To tune , you press radio and then use the << and >> buttons. If you want to tune manually in small steps, Press Go To, and then the << and >> buttons. Then preset as above. To change to AM from FM and vice versa, press the Turn button.
  • 03-10-2009 1:50 PM In reply to
    now I have the hang of it, thanks.
    the display cuts out quite quickly, I guess it is to save battery, but I don't remember it turning off the display so quickly before, so I changed the batteries, but it made no difference, is there a button to keep the display on at all times ?
