Latest post 05-29-2007 8:40 AM by Meng. 8 replies.
Page 1 of 1 (9 items)
  • 05-28-2007 6:18 AM
    Serene Menu
    Hi
    In the Serene alarm menu, obtained through the applications menu, there is a choice of different alarms. There is an 'auto power' either on or off. I haven't tried it but if I switch auto power on (I think off is default), exactly what happens next?
    Brian
  • 05-28-2007 7:01 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Serene Menu
    I'm not sure, but I think it means you can switch off the Serene and at alarm time it will still ring.
    Andy T.
    Poor me, never win owt!
  • 05-28-2007 8:26 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Serene Menu
    You can set your alarm and turn off the phone before you go to sleep, and when the alarm wakes you in the morning it also powers up the rest of the phone. I have always done this, and haven't tried it with this option switched off, but i'm guessing that just the alarm works and then  the phone is kept switched off.
  • 05-28-2007 10:02 AM In reply to
    Re: Serene Menu
    Thanks everyone, challenge resolved, one satisfied customer.
    Set alarm as usual, turn auto power on, then switch off phone. Alarm will ring at appropriate time, whilst switched off, and it stays off.
    Handy if you need to keep your phone off for battery conservation or if you don't want to be contacted.
    Brian
  • 05-28-2007 2:31 PM In reply to
    • Jandyt
    • Posts 13,004
    Re: Serene Menu
    Yes Warm glow. Big Smile
    Andy T.
  • 05-29-2007 8:33 AM In reply to
    • Jandyt
    • Posts 13,004
    Re: Serene Menu
    Yes Ed. Like press and hold * to get T9. Learning all the time.WinkWink
    Andy T.
  • 05-29-2007 8:40 AM In reply to
    • Meng
    • Not Ranked
    • Joined on 05-16-2007
    • Posts 70
    Re: Serene Menu
    Hi you guys, I was wondering if anyone from you could answer my question. Does the WAP Browser on the Serene support SSL? Anyone knows the answer?
