Is there any B&0 owner who may have an answer to my problem ?
I still have my old Beovision LX4500 which is going strong after almost 20 years of ownership. All this time, I used the TV without a motorised stand.
Now, I have just bought a second hand motorised stand ref. nr. MSMX55 on Ebay, which seems fine, only, the steel plate on top does not fit any of the holes underneath the LX4500 and I am wondering if originally there was an adaptor depending on the model of television you wanted to fit onto the stand.
The only threaded holes (brass thread) I can find underneath the LX4500 are about 70 cms apart, the steel plate on top of the stand is only 45 cms wide, by 13,5 deep.
Any idea someone out there ? A drawing or pictures would be very helpful. An original motorised stand owners manual or a copy even better.
Thanks for your interest.
