1st March February 2012
03-05-2009 6:25 AM
davefarr
- Joined on 08-21-2007
- France
- Posts 190
I can't wait 12 months for the next prizedraw!
A glitch in the system somewhere seems to think that the next draw is in 366 days! Unless Lee hasn't told us something.
Draw date?
Dave.
Am I ready? I was born ready!
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Re: I can't wait 12 months for the next prizedraw!
Interesting, the following is what I see using either Firefox or Internet Explorer
Keith Saunders
- Posts 3,810
I am assuming your statement "Seriously, it works for me too" means you are getting what I am getting ?
If you still have the problem, then you must be going through a "Proxy Server" located at your ISP (Internet Service Provider)
The proxy Server details would have previously been entered into your browser as should teh page below shows for Internet Explorer
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Keith Saunders:
Yes, both in Firefox 3.0 and IE6.
Seeing that it is JavaScript and uses the basic date and time functions, and thus is executed completely at the browser end, it will of course show potatos if your computer time is set incorrectly...
Keith Saunders
- Posts 3,810
tournedos:
You are correct..
Milton78
- Joined on 06-04-2007
- Posts 130
My computer tells me it's the 6 March 2009 GMT+1, and it's still 365 days and 12 hours left to the next draw...I know that we sometimes are a bit behind in Sweden but this is silly...
Have to check it from my Firefox comp then. May be that this old IE06 is the reason.
Keith Saunders
- Posts 3,810
If the problem only happens with Internet Explorer Version 6.0, then I suggest they may be a problem with the Javascript plugin.
You may wish to remove it and reload it.
Page 1 of 1 (13 items)
