Latest post 03-06-2009 5:00 AM by mayonaise. 10 replies.
Page 1 of 1 (11 items)
  • 03-05-2009 6:20 AM
    Beosound 1 - Funny noises
    Hi!
    My Beosound 1 makes funny sounds, as if something's cracking. This happens after I play a CD and turn it off. Sounds like it comes from the back. Not from the speakers for sure.
    Any similar experiences?
    Filed under:
  • 03-05-2009 8:43 AM In reply to
    • Dude1
    • Top 500 Contributor
    • Joined on 09-18-2007
    • London
    • Posts 189
    Re: Beosound 1 - Funny noises
    does it sort of sound like something is cooling?  I had a BS1 and after it had played for a bit then turned off it sounded similar to a car exaust cooling...I took it back but the dealer and service centre "couldnt hear it"
  • 03-05-2009 8:57 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Yeah i didn't experience any crackling, but maybe it's the CD part cooling. Mine has a high pitched hiss from the power supply, doesn't sound like your problem is serious, just irritating.
    Dude 1 of course they didn't hear it, they'd have to spend hours and fix it
  • 03-05-2009 9:26 AM In reply to
    mine does the same thing after being on for sometime,  sometimes it freaks the crap out of me if it happenes late in the night.
    Jon
  • 03-05-2009 10:54 AM In reply to
    jon, do u mean the hissing or the crackling?
    Sometimes, the crackling is pretty loud. Sounds like popping even.
    Kellogg's Rice Krispies?
  • 03-05-2009 10:56 AM In reply to
    cracking, like brittle plastic
  • 03-05-2009 12:24 PM In reply to
    Dave:
    What are you meaning here? That the repair centre have an interest in not repairing the beosound 1?
    If so; then you are of course mistaken.
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 03-05-2009 2:16 PM In reply to
    • Dude1
    • London
    • Posts 189
    Yeah, its funny that no one but myself could hear this noise.  I mean you would expect the technicians to have reasonable ears, when dealing with high end hifi...
    Anyway, i got rid of mine, it was NZ $3K and a sanyo stereo for $100 doesnt seem to make odd noises...
  • 03-05-2009 3:46 PM In reply to
    • Stan
    • Top 150 Contributor
    • Posts 593
    • Gold Member
    Mine cracks sometimes after I turn it off after I've been playing it for a while.  I have always assumed it is some parts contracting (after having expanded from the heat generated by the unit) similar to what a car does after you turn it off.  It is sometimes quite loud, but it has never really bothered me.
    I can understand a service department having difficulty reproducing the problem.  It doesn't happen always (at least for me), and probably depends on how long the unit is played as well as the temperature of the room.
    Stan
  • 03-05-2009 7:47 PM In reply to
    • Dave
    • Posts 2,328
    It has something to do with the temperature of the room, the B&O technicians would have a heated space to be working in, i live in a warm climate, and never heard the crackling sound, as the temperature didn't really change.
    Are you guys in a cold room when this sound occurs?
  • 03-06-2009 5:00 AM In reply to
    Loud cracking plastic is exactly what I get. I guessed it was the contraction of some materials as well.
    Not sure abt climates, as I had those sounds when I was living in hot & humid Asia and still have them here in freezing Europe.
    Never had those noises when the set was 1-2 years old, but now that it's like 5 years old, it's making them. Signs of old age?
