Latest post 03-29-2009 7:27 AM by stefan. 2 replies.
Page 1 of 1 (3 items)
  • 03-04-2009 1:15 PM
    Function_
    Hello and scuse me for my bad english....
    Can someone explain me what the 'function_' command is?
    I have tried to use it with a Lintronic in order to convert this command into a command to control an external  set top box, but it seems to freeze.....
    What is the correct use for the 'function_' command?
  • 03-27-2009 12:34 PM In reply to
    Re: Function_
    As far as I am aware the "Functions" have only been used with Lintronics to date and are intended for 3rd party control.
    The Lintronic relay card is a good example and teh following are the "Control" and "Function" commands
    CONTROL COMMANDS
    Control 0 = All relays
    Control 1 = Relay 1
    Control 2 = Relay 2
    Control 3 = Relay 3
    Control 4 = Relay 4
    Control 5 = Relay 5
    Control 6 = Relay 6
    Control 7 = Relay 7
    Control 8 = Relay 8
    FUNCTION COMMANDS
    Function 1 = On for 1 second
    Function 2 = On for 2 seconds
    Function 30 = On for 30 seconds
    Function 31 = On constantly
    Function 32 = Off constantly
    Function 33 = Toggle On/Off
    Function 34 = Reserved
    Function 35 = Reserved
    Function 36 = Reserved
    Function 37 = Toggle "Input 1"
    Function 38 = Toggle "Input 2"
    These are used with the "Light" command
    Regards Keith....
  • 03-29-2009 7:27 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Function_
    In addition to that Beo uses CNTL commands for PUC control via Beo5. For example if "GUIDE" is controled by MENU - 2 via Beo4 and GO - 2 from linkrooms it`s CNTL-2 via Beo5. The same for CNTL-0 - CNTL-9.
    Stefan
