Latest post 03-10-2009 5:26 PM by k984942. 4 replies.
Page 1 of 1 (5 items)
  • 03-04-2009 7:06 AM
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    DVD1 to Avant over digital coax: Sound in link room?
    Hi All
    I am just about to purchase a digital coax cable to pipe the sound from my DVD1 to my 32" RF VCR Avant in my main room.
    Before I do this, does anyone know if this will cause me any sound issues in the link room? Currently there are no problems playing and hearing a DVD's in the link room
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 03-04-2009 8:54 AM In reply to
    Re: DVD1 to Avant over digital coax: Sound in link room?
    There should be no problems. I have a similar set up.
  • 03-04-2009 11:51 AM In reply to
    • k984942
    • London, UK
    • Posts 194
    Thanks Zwets.
    What quality of cable did you go for? They seem to range from around £10 to well over £100 and there are so so many brands out there!
    Any advice would be much appreciated!
  • 03-04-2009 4:40 PM In reply to
    Second that.
    You will have the exact same sound in your linkroom as you have today.
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 03-10-2009 5:26 PM In reply to
    • k984942
    • London, UK
    • Posts 194
    I have now purchased and connected a digital coax cable. The only problem is I'm not sure the sound is travelling through it and not the SCART.
    Can anyone tell me how I can tell?
