Ok so while playing with my Avant today I tried to install a Picture in Picture module.
Its a Type 4141 and according to the booklet should fit into my Type 84/23.
It says it attaches to the PCB2 which is the video processing and teletext and then the ribbon cable connect to P35 on PCB2.
All very easy except the board itself is too large to fit as per the single diagram (I have another look for a better manual on here).
Also I can't seem to find P35 which should be about an inch across!
Anyone have any ideas?
Train Hard - Run Fast - Hit to Kill!!!
