Sorry for the delay in replying, I've just seen your post (the past few weeks have been very busy!)
Beogram 7000 (1992-1994) should have a captive Datalink cable with a 7 pin DIN plug fitted as standard, whereas from memory I think the earlier Beogram 8000 (1981-1982) had a 7pin DIN socket on the back so that a removeable lead could be fitted, as per Chris' comments.
Hence, if a previous owner has replaced the captive DIN plug on your BG7000 with RCA plugs, you have two options:-
1) Add a twin Female RCA to 5/7 pin DIN cable to allow connection to your B&O system without any modification, although the Datalink function will not work.
2) Have the turntable modified to replace the RCA plugs with a 7 pin DIN plug, so that the turntable can be used with your B&O system and the Datalink function will be fully operational.
Let me know if you need any assistance with either option.
Regards,
Steve.
PS. Thanks for your kind words Chris!
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
