This happens when the highvoltage begins to change due to wear and tear...
The tube is probably not the problem, this type of philips tube is one of the very best tubes ever produced. It's very resistent and durable.
You should begin to replace the caps of the mainboard. Since the mainboard is still working, it's really not a big deal to replace around 20 caps. Then most of the parameters of the tube are in spec again.
