Latest post 03-01-2009 1:51 PM by pf85. 3 replies.
Page 1 of 1 (4 items)
  • 03-01-2009 3:10 AM
    • pf85
    • Top 500 Contributor
    • Joined on 04-21-2007
    • Posts 145
    fully integrated audio master installation BS 5
    Hope some experienced colleague can help.
    I have BS 5 with an Avant (older model but takes N.music / N.radio commands, no video), BS 3200 and now BS 5.
    BS 5 works well but seems to lock BS 3200.
    When I ant to operate CD on BS 3200, the system locks. If I disconnect BM5 / BS5, BS 3200 works again.
    Anything I have overlooked as to how to setup BS 5 in the system ?
    Expert advice appreciated - thanks
  • 03-01-2009 4:17 AM In reply to
    Re: fully integrated audio master installation BS 5
    pf85,
    Your description indicates you use a BS5. Do you mean a BS5 with a BM5 or do you mean a BM5 "black box" only.
    I would imagine you need look at both your option settings for the Avant (V.opt 2), the BS 5 (Full Maintenance Mode, Roles, Audio Master off, A.opt 0) and BS3200 (A.opt 0).
    I would download the Product Configuration Guide (latest one with BS5) and go through the combinations. I think the key irrespective of option settings is to have the Audiomaster "off" or "on" depending on what you have now.
    I run a BS5 with BV7 and the PCG indicates to run Audiomaster "off" but I find I need it "On".
    10%
  • 03-01-2009 5:57 AM In reply to
    • pf85
    • Posts 145
    Thanks for your recommendation and apologize that I was not specific enough. I run Beosound 5 with Beomaster 5, so both. Will work on your recommendation and go through the combinations.
    When clarified will post it.
  • 03-01-2009 1:51 PM In reply to
    • pf85
    • Posts 145
    With BS 3200, BS5/BM5, it looks as if the setting with BS 3200 als audiomaster seems most robust. Once BS/BM5 was set to Audiomaster off / 0 no more system locks. Will fiddle a bit more and see if all the functionality works proper.
